I purchased this a few months ago, whenever I plug it into my laptop and try to do anything on it - open a file, move/transfer a file/folder, etc - it freezes for 10+ seconds and it’s not responsive. Also, the transfer speed when I do get it to work is quite slow, definitely not 1050 MBps as advertized. Is there a fix for these issues?
Hi @badrology,
Thanks for reporting the issue. Have you opened a Support Case? If not please click here and open a new support case to assist in the best possible way.
Hi.
I’m experiencing the same issue. Is there any solution availiable?
