Hi to all!
My Sandisk Extreme 64Gb when plugged into USB ports controlled by chipset don’t work !!!
they work like USB2.0.
This is my hardware configuration:
Asus F1A75-M Pro
AMD A8-3870K
Crucial M4 64gb
2 x Corsair Vengeance 8GB DDR3 CMZ8GX3M2A1866C9
Case Silverstone TJ08-ESilverstone
EC01-P expansion card USB 3.0 http://http://www.silverstonetek.com/product.php?pid=327&area=enhttp://www.silverstonetek.com/product.php?pid=327&area=en
Silverstone FP37 card readers + USB 3.0 port http://http://www.silverstonetek.com/product.php?pid=315
Bios version 2206 (latest version)
Please, note: each time the installation is not successful, I reinstalled everything again I do this :
unplug expansion cards
unplug any device from usb ports, 2.0 & 3.0
configure bios, I tried different configurations: ASmedia controller enabled or disabled, legacy support for USB2.0 & 3.0 enabled or disabled.
format
install windows
install chipset driver: AMD_Chipset_V512013 found on the motherboard support page, and after I try this one 13-4_vista_win7_win8_32-64_sb found on AMD support site.
but don’t work …
when I plug the pendrive, windows say “… this device can perform faster if you connect it to a … 3.0 port …”
System Properties>Hardware>Device Manager are ok I do not know what I can do … ![]()
I apologize for my wronged English Thank you very much
