I can not get my Motorla G to regonize the Sandisk. I have downloaded the memory Zone app but still does not work. Any suggestions ?
What version of the Moto G do you have? Some versions may not support OTG. You can download an OTG check tool from the google play store to check your phone to see if it is compatible.
Check the thread below. ![]()
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Dual-USB-drive-16GB/m-p/318575#M8405
