SanDisk Dashboard supported models
Hey,
I need an SSD that supports the SecureErase function. I read that SanDisk does that through the SanDisk Dashboard software. Which models are supported here? All I could find was that some might not be supported, but not an exact info about which models are. Is the “SanDisk Extreme Portable SSD 1 TB USB 3.1” in particular supported?
Thanks for the help!
Hi @faded_to_black
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
