fails to install after being uninstalled even after reboot.
repro: uninstall, reboot, try to install again, see unknown error and suggestion to try after reboot (not helps)
expected: can install after uninstall
@luxferre The SANDISK Dashboard is version 5.1.2.2 which can be obtained from Sandisk Product Software Downloads | Sandisk. If you are having problems with our official version try deleting C:\Users\USER_NAME\AppData\Local\SanDisk\Dashboard and this C:\Program Files (x86)\SanDisk\Dashboard after the uninstall, reboot, and install again.
Delete leftover app folders in AppData & Program Files, run installer as admin, that usually fixes the unknown install error.
