SanDisk Cruzer Blade 16 GB Disk is write protected error
whenever I try to move/ copy any file from/to the drive I face this error.
The disk is write protected, even when I try to format it this error appears.
Am using windows 7 sp1 and I tried it in othe PCs with Windows 7, Windows XP and Windows server 2008 R2 and the same problem happened.
Any Solution ti this error?
Have almost the same problem on my 8gb flas drive.  I gan write files to my valut, but not open them… pretty useless.
Also in the Valut I can not index my files according to size and date. pls upgrade.
Andreas
Your’s is a totally different problem andrstov.
@sh4d0w wrote:
Me also facing the same problem, i manage to copy all the files out of the device, but unable to cut, delete or paste in the device.
When i right click at the blank area, paste function is disabled. Help!!!
‘The Disk Is Write Protected’ shows up!!!
write protection is comman problem so don’t take it serious… Check this
How to fix Write protection in sandisk pen Drive
