Sandisk Cruser U3 16GB file format raw
Hi I have a SanDisk cruser u3 16Gb thumb drive. Seeing as I plug in the PC hardware and file format, but sees 16MB “raw” I wanted to throw a variety of programs
but it gives error. I can not enter into the disc in. please help
Same issue with brand new Ultra 16GB flash drive, abeit it shows up as 64MB partition. It might be bad :confused:
"Seeing as I plug in the PC hardware and file format, but sees 16MB “raw”"
It aounds like it got yanked out of a pc without using the Safe Removal option and the FAT is screwed up.  Try running CHKDSK on it and see if it can fix the problem.
“Same issue with brand new Ultra 16GB flash drive, abeit it shows up as 64MB partition.”
You’re looking at the U3 CD partition.  Once you run the LaunchU3 program you will be prompted for the password to access the writable partition.
