Running two readycache - will I see any benefit?
Hi Folks,
Not sure if this idea is new or if someone has some expereince with this setup already. Can you tell me pleae if there is any benefit to running two installation of Sandisk Readycache?
Or are you better off with just one readycache unit and a separate SSD?
Also I am think of getting the 750GB Seagate Momentus XT hybrid drvie. Will the readychace compliment this hybride HHD?
Thanks.
no, you would not see any benifeit. Expresscache is designed to work with only one SSD.
Cheers for the tip.
What about working in concert with Seagate XT hybride HHD - SDD? Will it be mutually beneficial or no benefit at all?
