Request for IBIS Model for SDINBDG4-32G-XI2
Hi Team,
I am unable to find IBIS Model for SDINBDG4-32G-XI2 . Please provide the needful.
Thanks,
Kuralmozhi
Hi @Kuralmozhi
(Get Support for Your SSDs and Flash Products | Sandisk)
(Contact Support | Sandisk)
The IBIS model for SDINBDG4-32G-XI2 is not publicly available and is typically provided by SanDisk or Western Digital under NDA. You can request it through their support portal or contact your company’s FAE or account manager. A generic model from the iNAND 7250 series may also be used if available.
Hi @Kuralmozhi,
As mentioned by @johnjacobb40, the IBIS model for SDINBDG4-32G-XI2 is not publicly available and is generally provided by SanDisk or Western Digital under NDA. You can:
  1. Request it through the SanDisk/WD support portal: Contact Support
  2. Reach out to your company’s FAE or account manager if you have one—they may be able to provide it directly.
  3. If applicable, you may also consider using a generic IBIS model from the iNAND 7250 series as a substitute, if it meets your simulation needs.
In addition, you may also want to check the SanDisk knowledge base for any product-specific documentation or updates: Get Support
