OK, I got bitten by the ReplayGain bug THREE times this morning on the bus on the way in to work in a 35 minute period.
That’s three times too many.
What is the status of the fix and when can we expect it (BTW, I have a V1 Fuze - so the problem isnt limited to V2 playes as the popular myth would have oyu believe)? This is the one and only advantage my Fuze has over my Cowon I7 and if Sandisk can't get their azzez in gear and fix it, the player becomes useless to me. A feature isnt a feature if it doesn`t work and if I can experience it that frequently, there is absolutely NO excuse for it slipping past QA - assuming QA is actually AWAKE.
I just made a recommendation on deviantArt to someone looking for a quality player that they look at either a Fuze or a Clip+. That kind of recommendation is getting harder for me to make.
I don’t have a link to the post, but I believe Sandisk said that a fix is in the works and it will be released as soon as it’s done and it passes QA, instead of waiting for the next scheduled update. They weren’t more specific than that.
What I’m experiencing is that the Fuze will play fine and then on switching to a new song it will drop the volume so low that it will be inaudible. Turning it off and on will not necessarily cure the problem. It will also happen randomly without warning or pattern. It’s VERY annoying.
And as I said, I aparrently have a V1 Fuze so it’s not limited only to V2 players.
Today I downloaded and installed a firmware update via the Sansa Updater dated October - and this is for the V1 Fuze (the version begins with a “1” and my understanding is that the rev version begins with “2” only if I have a V2 fuze). It’s a .28 and not a .26 release.
The latest .28 release _ is _ the one with the bugs, hence the recommedation to rebert back to the .26 version. It says it’s limited to the v2’s only, but there are those with v1’s claiming the same issue.
I am running v2…28a and noticed that I have no control over the gain. It is either 0.0 or nothing. Is this the bug? I haven’t noticed level drops on songs I am playing.
