Does anyone know how I can get replay gain to work on the clip zip? I want to make some quieter mp3s the same volume as my others. I’m using Fedora 17 and can also run Foobar2000 udner wine if that’s any help.
Thank you!
Thank you!
Thank you!
You need to use Foobar to do a ReplayGain scan of your files, and then it will ask you if you want to update your tags with that info and then say yes. After that load them on your player, and make sure RG is enabled on the player.
Do I scan all my files or just the ones that needa voluem increase?
