Readycache without ExpressCache
I need an SSD for my old laptopt (SATAI), can I use the Readycache as a regular internal SSD drive to install my OS (Linux and XP) on it?
I read the FAQ and it says something about “formatting the drive” so I suppose I should be able to install it as a main drive, but I wanted to double-check just to avoid surprises.
Thank you for your time!
yes, you can use the readycache ssd as a normal ssd.
