I have a Win 7 64 bit SO
My SSD SanDisk ReadyCache 32Gb is not found by ExpressCache
Why!
the i100 is not a readycache ssd. The software you are using is the retail version and only works with the ReadyCashe SSD part number SDSSDRC-032G-G26 which is a 2.5’ SATA SSD.
Tnx.
What kind of softweare should I use then?
I would to use this ssd disk for accelerate my HardDisk
Software should be available from the computer manufacturers website.
If you do NOT activate _ExpressCache_within this time frame, caching will.
