Project Sub-Ohm Edition UWELL Valyrian 2 Mesh Sub-Ohm Tank
Description:
Project Sub-Ohm? and UWELL have teamed up to create the Valyrian 2 Mesh Sub-Ohm Tank which has identical specifications of the Valyrian 2 Sub-Ohm Tank. This limited time offering from PSO features their unique Black and Blue color combination. While the original Valyrian utilizes custom rods to disrupt the airflow passing through the coil to achieve enhanced flavor from the e-liquid, the Valyrian 2 has adopted mesh coil technology to achieve the same quality of flavor. The Valyrian 2 vape tank integrates several key features to make this tank easy to use while achieving great vapor and flavor production. These features include a patented self-cleaning coil system, Pro-FOCS Flavor Testing Technology, and an optimized flip cap design.
The Valyrian 2 uses the same patented self-cleaning design found on the popular Crown IV Sub-Ohm Tank, which allows any condensation that may form at the base of the atomizer head to be re-absorbed into the coil. This system helps prevent leaking from over-wicking and condensation build up. The Valyrian 2 vape tank also uses UWELL’s UN2 mesh coil technology which has a larger heating surface and heats evenly for maximum efficiency. UWELL offers four atomizer heads to choose from; UN2 Single Mesh Coil, UN2-2 Dual Mesh Coil, UN2-3 Triple Mesh Coil, and a Quadruple Round Wire Coil. The Valyrian 2 Sub-Ohm Tank includes a pre-installed UN2 Single Mesh coil and a UN2-w Dual Mesh coil, while the others can be purchased separately as a replacement coil pack.
A bubble glass section comes standard on the Valyrian 2 and has a total capacity of 6ml that can be filled with your favorite vape juice. UWELL has also included a spare bubble glass section in the vent that the crack resistant glass has an impact hard enough to crack it. Filling the tank is made easy thanks to the spring loaded, button activated flip top design. One can simply press the top cap release button to spring open the top cap and fill the tank through one of the large fill holes.
Color: blue and black
Uwell Yearn Replacement Pre-filled Pod Cartridge 1.5ml 4PCs Mixed Flavor
