url=[https://worldvaporstore.com/product/skol-device-pre-filled-pod-system-kit-2ml/]Skol Device Pre-filled Pod System Kit – 2ml[/url]
Description
The Skol Device Pre-filled Pod Kit is powered by 300mAh built-in battery and can provides about 200 puffs. The kit includes a magnetic charging base that can be fully charged by only 15 minutes. In addition, the Skol Device is an ultra-portable closed Pod Battery and is perfectly compatible with Jull Pods and various amazing tasting Skol brand prefilled pods. If you want to find a cost-effective pod kit, The Skol Device Pre-filled Pod Kit will be your best choice.
Main features Brand:Skol
Material: zinc alloy + food grade PCTG
Battery: 300mAh built-in battery
Capacity: 1.0ml
Resistance: 1.6ohm
Power: 5W
Fully compatible with Jull Pods
Perfectly fit Skol brand prefilled pods
Include a magnetic charging base
Compact and portable pod with mini size
Pre-filled pod with 1ml e-juice
Only take 15 minutes to recharge
Suitable in various places
Color: Blue,Pink,Silver,Black,Red Package Contents 1 * Skol Device Pod kit
1 * USB Charger
1 * User Manual
