Problem with my sd card
Hello I just purchased a new sd card and an adapted from san disk,but the problem is anytime I put the memory card and adapted in my camera it says memory full and it’s completely empty,and even when I formatted the memory card on my pc (Windows 10. 32-bit) and put it back in the camera it still didn’t work it said memory full please help as soon as possible.
did you check if the card is compatible with the camera first?
is it an sdxc card and your camera supports only up to 32 sdhc?
Dont worried about it. You can check your  camera setting or search in google for better help
