Problem with installation of WD SmartWare
When I plugged my new “My Passport Essential” into one of my USB slots. It auto-installed the drivers needed for the hardware, so then I went to install the “WD Smartware” software from it. However, during the installation process, it becomes stuck at “estimated time remaining: 25 seconds”. And then i get a error message that he can’t find the file.
I have a PC with windows vista.
i have the same problem with the install of WD SMartWare on a pc with Windows 7.
Please help.
OKay,
the new version 1.4.1.1 works…
WD SmartWare 1.4.1.1
Doesn’t work for me?
Don’t waste time with Smarware it’s junk. Try this instead http://support.wdc.com/product/downloaddetail.asp?swid=119&wdc_lang=en
Joe
Wow - it seems to be just the same problem I recently discovered with my nes Passport Essential - se my recently post on the subject.  Have you contacted support-service on this?  At this time it is bed time in Norway, so I go for some sleep …
Wow - You saved me - the new version solved all m problems - 1.4.1.1 - Thank you :slight_smile:
