I just bought a 500 Gb My Passport Essential USB 3.0 Hard Drive, I manually installed the WD Smartware software I found inside the Hard Drive folders, but it doesn’t seems to end the installation and hungs on 25 seconds to the end everytime I try to install it. I installed it on other 2 different PCs and it worked.
I have Windows Vista on this PC.
At first: why I need to find the setup files manually? It doesn’t auto-start, and that’s a big problem for less skilled people who don’t know how to find the drivers manually, don’t you think?
How to solve my problem? I can see the Hard Disk folders, so I can use it, but I want to install the drivers correctly and avoid all that Windows popups about the installation fail.
Hi I have just purchased My Passport Essential WDBAY5000a and I am having major problems trying to install the Smartware installation.
Everytime I link the drive it will not let me load the SES driver and detects it as a new hardware everytime - I have tried going into the specific location and select drive E to download this manually and this has not worked.
I am also unable to download the Smartware software - every time it gets to 1/3 of the progress bar it shuts down and will not upload - i have looked at the forum, uploaded the Microsoft.net, turned off antivirus and firewall and this has made no difference.
Yesterday I tried to install the default driver for the last time, before following your instruction. Well, after 20 minutes of pending it worked, don’t ask me why because I really don’t know.
Now the WD SmartWare is running and seems to work good. In case of problems, I will install the driver you suggested.
Just if I am trying to load the software the time bar goes along for a while then shuts itself down.
I still cannot load the drivers however the computer does recognise it as a new piece of hardware when I plug it in however then states the this is a fault.
Did you get a Windows update? Because the SES driver comes in later updates of Windows. Make sure you have all your latest updates for your motherboard drivers as well as for Windows.
