I had to reinstall Windows 7 on my laptop and cannot reinstall WD Smartware. When I try to install WD smartware a small window appears with the text ‘pending_reboot_txt’ and when I click the on the OK-button, WD Smartware is not installed. Can anybody help me?
Hello and welcome,
Be sure to install the latest Smartware version (2.2.0). Check below for the download link.
Thank you for looking into my problem, but unfortunately it didn’t work. I (tried to) enclose a screenshot so you cn see what my problem is.
Martin
Hi Martin_Fields, please check your private messages.
Thanks you for helping me out. An expert of WD called me and guided me though the installation. He was very helpful.
It will be really helpful if you could show some demo so that I can install it properly.
