Hi guys,
The thread http://community.wdc.com/t5/WD-Software/WDsmartware-building-etilqs-files-in-my-windows-temp-folder/m-p/307856#M4152 would appear to be closed, and so I could not add this reply.
As a possible cure for etilqs_… files filling up hard drive DO CHECK THAT the culprit is NOT FIREFOX, or your ANTIVIRUS SOFTWARE causing the problem!
It may not be WD causing the issue… ![]()
Here are some (I hope helpful) other FIREFOX related issues I have copied here…
INFO
- That are temporary SQLITE database files (etilqs is sqlite spelled backwards). Such files shouldn’t be here. The presence of such files can be caused by security (anti-virus software) that keeps a handle on such files for inspection and makes it impossible to remove them.
- You need to check such software and exclude that folder from their scans.
REMOVAL
“if you want to play it extra safe, i would recommend moving those files somewhere. Then see how it goes, if it runs smooth for a few days, i would say its safe to proceed with deleting.”
http://discussions.virtualdr.com/showthread.php?252595-etilqs-how-to-view-and-remove
Hope that may help
Peace Man ![]()
