pls ans me
pls send answer wht do … my sandisk pen drive problem
You can post your issue here so we can discuss it or you can directly contact the support of sandisk to get a solution to your issue.
you can contact them from here: http://www.sandisk.com/about-sandisk/contact-us/
deponia - Please note this post is 5 months old. Really no need or help to respond after this long.
And frankly, the reason no one responded before this is most likely because the OP did not give any details about their issue.
Ok thx for the info and advice i will try to keep that in mind for the future posts.
