I think the PS3 may not be putting out enough power to run the drive. You might try a power booster cable. It’s Y shaped and uses 2 prots on the device supplying power. Personally I would get a powered drive instead of a USB powered one. Unless you want the Smartware I’d also recommend the Elements drive.
