Passport 2TB USB3, on Mac OS 10.8 MBP, bought just 3 mons ago been working fine. Formatted as NTFS, just readable on Mac.
Started to eject by itself - sometimes it still shows as mounted but can’t browse or see folders / files. It seems likes its fine until I start doing some heavyish data transfer from (or to) the drive. Files all look like they’re there but haven’t verified.
What can I do to test where the fault lies and get a fix?
Also, in Win8, ran a Check for Errors, and downloaded the WD disk utils and ran a Quick Drive Test and both are ok.
Started to copy some files off and the drive ejected…always mounts / connects fine after I re-connect. The file copy operation threw up a dialog of course as it ejected half way through the copy. Reconnected and did Try Again and it continued to the end.
Another piece of data…once got a Mac error code of 36 when transferring files.
