I got my My Passport Wireless so that I could keep my iTunes and iPhoto (Apeture) files on it. The DNLA stuff might be fun to play with some day, but it doesn’t seem to work with much.
First important point: I have no idea why, but, yesterday, I had it working:
I transferred my iTunes library through USB
I connected to it through wi-fi (I’d prefer if it got an address through DHCP as I usually use 802.11ac, but it worked)
I played a film
It was a bit jerky a couple of times and went out of sync once, but it worked - these problems are probably because it’s a slow connection (1m from the laptop, but it’s only 802.11N) and because it’s formatted as FAT, not HFS+).
Still it worked.
Then, when the film ended, I tried to run another. The drive had disconnected - it was on USB power.
I’ve not managed to get it going again.
Now, when iTunes tries to access the drive, I get the error:
The iTunes Library.itl file is locked, on a locked disk or you do not have write permission for this file.
I’ve looked at the file permissions and they look fine:
-rwxrwxrwx@ 1 peterbrooks staff 4400726 21 Nov 21:36 iTunes Library.itl
That’s exactly as it should be.
I’ve now spent an hour or two trying different things, like re-booting the drive, changing the permissions on the files etc. etc. - no joy.
Any idea what’s going on??
----- Problem II:
Also, another problem. I wanted to have a look around to see if there was some problem caused by config files or something - the browser GUI has very few options.
So I tried SSH - exactly as recommended in the manual:
ssh admin@drivename.local
password:
I put in the password that came with the device: welc0me
It says incorrect password
I tried the password that I’d set for the browser login - that didn’t work
I tried root and other users no joy.
So I contacted WD. They say ‘ssh is not supported’ - so they have, apparently, no idea why it isn’t working and don’t care - despite it being clearly documented in the manual…
I wrote back to WD a couple of days ago - no reply back yet.
Anybody here got an idea what this other problem might be?
