Hello there, I am hoping someone out there can help me please… Basically I have a passport ultra 1TB as the family backup external drive and upon checking it recently there is only 32GB capacity showing (30GB used, 2GB free). I have now found that the is 0.9TB on a lost partition, can anyone tell me how I can recover this at minimal cost, I really only need the lost photos… Thanks, Matthew.
Hello Matt1leeds,
You should take a backup of important data from the drive then reformat drive and create partitions to use the complete storage provided by My Passport Ultra.
Thank you for the feedback!
This usually happens when a 1TB drive is accidentally used with Windows’ Media Creation Tool, which shrinks the drive into a 32GB partition and leaves the remaining 0.9TB hidden and unallocated.
For now, you should stop using the drive to save new files and avoid formatting it. Instead, download a data recovery program that supports lost partition recovery to your PC. You can then export the rescued photos to your computer’s internal hard drive—not back onto the Passport hard drive. Here is a further guide on how to recover your data: How to Recover Deleted/Lost Partitions on Windows 10/11
