Hi, all,
I have a WD Elements WDBAAU0010HBK external hard drive which is not recognized by my computer. It connects with an USB, but have separate power cord.
https://www.cnet.com/products/wd-elements-desktop-wdbaau0010hbk-hard-drive-1-tb-usb-2-0-series/
I can’t say for sure, but I’m not surprised if it’s 15 years old. At least 10. I also can’t say for sure how long it’s been, but it has not been working for at least the 5 past years. I’ve just been very slow to adress it, but want to fix it now as it’s full of pictures and personal files.
Note: Is there supposed to be a power light? I can’t remember this from when it used to work. But there’s certainly no light on it now.
It seems like this is a common problem. I’ve tried most of the solutions that typically pop up. For example, my disk does not show up in Disk Management as re-naming the drive seems to be a popular solution. But it’s not even there.
Any advice?
The only thing I can think of personally right now is to go to a store and see if they have spare cables and then check if those work.
I’m 100 % certain it’s not been physically damaged.
Thanks in advance!
Best regards,
Johannes
I have a newer computer and I see that this old drive is USB 2.0. My newer computer is USB 3.0.
Can that simply explain this?
If so - is there a specific cable I should get?
Yes, there is supposed to be a power light to indicate that the device has power.
I have one of the hard drives and it still works fine
Maybe you have a dead power supply or the wrong power supply ?
The WD AC Adaptor I’m using a 12V 1.5A
Nope
Mine works fine via USB3.0 ports … directly on my PC or plugged into a USB3.0 Hub using the original USB2.0 cable that came with the drive … which is the older type Mini USB
There’s a number of reasons why your drive is not working … i’ll list them
Wrong or Dead Power Supply
Enclosure is Faulty … but, the internal hard drive can be removed and placed into a 3rd party enclosure. Have done this myself putting it into a USB3.0 enclosure to quickly copy and backup data … then returned it into the original case
USB Ports on the enclosure can be can be Dry Jointed after years … i bought 2 of these hard drives at the time and 1 was faulty due to bad USB port connection.
Mini USB cable faulty ?
etc etc
Hi, Joey,
Many thanks!
That’s the one, yes. I just couldn’t recall that light, but it’s been so long that I probably forgot it.
I think my first step then would be to head to a nearby store and see if they have any spare cables I could test.
Is this something I could do too on my own or would professionals have to do it?
At this point - my only concern is to restore the data. Salvaging the drive itself is of less importance.
Best regards and thanks again.
Johannes
Hello again!
Well, I took another power cord and tested it and it worked!
So it was simply a faulty power cord.
Thanks again.
Johannes
