want to install this on new laptop running windows 8. was not sure what to select from WD site. Can someone help this old gal with link to installation.
thanks in advance to all
Elements is a simple plug and play drive with no software to install. Just install the driver if prompted.
Joe
Joe
thanks much. I guess you can tell it’s been awhile since I last used it
guess the kudos star is asleep i clicked it several times and number never changed i did try
HOW DO i GET IT SOFTWARD.IF IT WILL WORK WITH MY OLDER MODEL# WD550P032
