I can’t find where I can modify the access point on My Passport Wireless Pro.
I can’t the 3 tabs : 2.4 Ghz, 5 Ghz and advanced.
How can I access it ?
Thanks
Best regards
Ghislain
Thanks
Best regards
Ghislain
Hello GhislainBruyere,
Open the Dashboard of the My Passport Wireless Pro
Enter the Wi-Fi page and open the Access Point Settings
Thanks for your reply but I don’t have the “Access Point Settings” link.
I’m using the last firmware
Could you please give me a feedback ?
Thanks
Click on the “Edit” button in the middle box. That will give you the Wi-Fi settings of your MPWP.
I can’t change the wifi network name here.
It still “My Passport (2.4 GHz) - xxxx”, I can’t change it.
Refer to the complete user manual downloadable from WD support. It is all explained in there.
