Hi, I may be being stupid but after I updated to firmware version V02.03.33F I’ve lost the volume setting in system settings. Now nothing is loud enough. Can antone help otherwise I’m going to get an iPod?
If you had typed in “low volume after firmware update” into the little search box in the upper right-hand corner of any page here, you would have been rewarded with this little gem (plus multiple others):
which explains the reason and the work-around. ![]()
