No acces to My Passport
‘No acces’ is all it says in the pop-up when I click on the map of the My Passport 07A8. Right clicking and going to Properties shows the disc is working like it should and has the latest drivers. I tried it on 3 computers. It’s an oldie and it’s over 90% full, could it have to do with a Windows 10 update? Help!
There could be a few reasons why the drive is not accessible. The drive itself could have failed, the partition on the drive may be damaged, the data cable may no longer be good, or the drive may no longer be getting enough power to fully spin up, Incompatibility with OS.
Please refer to this KBA for troubleshooting: Error
Sometimes there is Windows cannot access the disk error occurs in the system. Usually, this type of error is associated with Windows Explorer, but the reasons can be improper operations, virus, or even a faulty power connection. However, to fix this problem you can try the below methods:
  1. Check your drive connection
  2. Change your drive letter
  3. Run CHKDSK in Command Prompt
Further, you can also check the below link:
Hope it helps!
