I bought it only to use for my xbox 360, but when I plug it in to my xbox it only has 32 gb to use. I have tried to format the WD passport to FAT32, but when I plug it in my xbox and configure it to make compatable it says 32 gb again.
How are you trying to formatt and what OS are you using? It’s the FAT32size limitation causing the problem so you probably need a third party tool like EaseUS Partitin Master http://www.partition-tool.com/personal.htm This may help too
I tried the DOS method, and being impatient as I am, when it was still at 0% at 10 minutes I stoped and tried a different method. I used the Verbatim SmartDisk method, and it formated with ease, but when I pluged it in to the xbox, and then configured it, it only had 32gb to use. This is what I had done yesterday to try and format it, I haven’t tried the other methods yet.
I am using windows 7.
I am also not familiar with any of this, so I fear I am doing something wrong somehow.
