try to get it to work with xbox360 like my old one does
If this is one of the newer models of the Passport series then I recommend you to remformat the drive to FAT32. These new series of drives come pre-format as NTFS as factory default and it seems like the Xbox and PS3 can only read drives formatted as FAT32. For more related information on this topic please visit the knowledge-base article below.
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3308&p_created=1236013748&p
If you would like to have instructions or at least a guide to help you reformat your drive on your computer, please see the link below for another helpful WD knowledge-base article that will provide you this information, and it also has pictures so you don’t get lost.
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3865&p_created=1258601352&p
