I have an old 500gb hard drive, model - WD6400E035-00 and I can not find my cord anywhere… basically I would like to know what the specific name for the power supply cord is for this model.
Thank you kindly.
Thank you kindly.
This drive uses a 12 Volt, 1.5 amp, 18 watt power supply. Theya re out of stock right now on the WD Online store but you can get a generic power supply of the same rating and use it instead if time is a factor. I have provided a link to the store site where you can register to be notified when they are back in stock.
https://www.wdc.com/products/accessories/18w-power-adapter.html#WDPS071RNN
Hi camber ,
As mentioned in the above post from @Timothy_G , you can get the power cord from your nearby local store or online as it is out of stock on WD Store.
Thanks!
