Hello!, I have a WD Elements 1.5 TB USB 2.0 Desktop External Hard Drive model number wdbaau0015hbk-01. Here is the WD web page for the device
http://support.wd.com/product/install.asp?groupid=304&lang=en
but there seem to be no specs to indicate what power supply it needs. I lost mine. And, there are no power specs on the device. I do not have the original box. Please advise on the specs for a replacement power supply.
THANKS!
fantastic. Just to confirm since I have tremendously important data on this drive… can I be 100% sure that these are the correct power specifications for a power adapter for this drive?
12 Volts
1.5 Amps
18 Watts
I can see that the pdf at the bottom of that post lists just the adapters with specs like barrel size which is helpful
http://wdc.custhelp.com/ci/fattach/get/100048/0/session/L2F2LzEvdGltZS8xMzk0MTIyNjYxL3NpZC9hOWhHd3pPbA==/filename/Power+Supply+Matrix.pdf
But since the drive unit is not labled with power specs and the data sheets do not have those specs either, how are you certain? Are you tapped into a WD internal database? My data was not yet backed up when the adapter was lost and it is important.
Thanks so much
The link I have provided in the previous post is from the WD Official web page. According to this link the power specs for your drive (wdbaau0015hbk-01) are:
12 Volts
1.5 Amps
18 Watts
You can click on the link below in order to purchase it from the WD Store.
http://store.westerndigital.com/store/wdus/en_US/DisplayAccesoryProductDetailsPage/productID.108411100/categoryID.13096000/parid.13092600/catid.13096000
