I have an older MyBook Essential, model number WD8001032. It was originally used on a Windows desktop, then for a while I used it as a “Time Machine” backup on a MacBook. I need to use it on a Windows notebook computer, to copy files before reformating the hard drive. When I plug it into the computer, it says a USB device is attached. But there is no USB device showing on Windows Explorer.
I have tried on two Windows computers with the same results.
Was The Drive Connected to a Mac? So Was the Unit Formatted for FAT32 or HFS? in That Case if the Unit Was just Formatted For HFS ( MAC ) it Will Show As an unknown Partition Under Disk Management in a ( WINDOWS ) and Due to that Is not going to be Recognzied under Computer ,
->If it Was Formatted For FAT32 Then it Should be Recognized at 100% , Since it is Not , You Can Go To Disk Management To Verify What is Happenning or Device Manager
-Right Click on computer or My Computer , Select Manage and In Computer Management you will have Disk management and Device Manager where You Could verify Whats The issue…
