i bought 2 1Tb mybook live HD, one for me and one for my sister. i wanted to be able to use access the drive through my xbox and computers at other locations. I installed my sisters device and it works perfectly. when i tried to install the drive on my laptop i found that, my disk drive was broken so i downloaded the image file of the cd and tried to install that way. everything seemed to go okay, discovery and installation of the smartware but when i tried to access the user interface i get a web page not found error. i can happily transfer to and from the HD using the folder on my desktop or folders in my computer, i can view and access the HD in my network and can stream from twonky on my xbox. if i can’t access the UI i cant register to access my cloud from outside my network and i also can’t set up users which is something i’d like. i tried using the disk on my pc and i have the same issue. IE address bar goes to a local ip when trying to connect which i can ping successsfully, so i tried googlechrome and firefox and i get similar errors
LAPTOP vista pro, PC XP, Router sky (lists mybook live as connected device)
Any advice would be appreciated
