You have to forgive me as this isnt my mybook as Im trying to figure it out for a friend.
It seems he cant see the hard drive in Windows. The Virtual CD seems to register and show up in windows explorer and it sounds like the Hard Drive is listed in the Device Manager but he cant access it or see the hard drive partition in Windows Explorer.
As I’m very unfamiliar with the mybook is there anything I can do to trigger it to show up again?
Fisrt try some other USB ports and make sure the cable is seated. Something strange that just turned up on powered drives is turning the plug 180 deg in outlet. See if either of those help.
Good tips Joe but I’m afraid I just got the same problem today. Lights are on but nobody’s home. I briefly got one start up sound coming from inside the Book, but that is all. Now, I’ll plug it in and get no sound, just lights that blink.
Even more important of a question, if in fact it is “broken”, is it possible to recover the data?
Is this a powered or USB powered drive? They make a power booster cable that uses 2 USB ports on PC. If it’s still under warranty you can contact customer service and they will probably send you a new power supply. Does the drive show up in disk manager or device manager? The data may be recoverable but if you open the drive without premission you void the warranty. It sounds more like a power issue than corruption. I know the thing about turning the power plug sounds stupid and shouldn’t make any difference but it does sometimes. Somebody stumbled on this last week and there were several more posts where it worked.
It’s USB powered. I purchased it in April/May of 2009 so I don’t believe it is under warranty. It shows up on disk manager and device manager as My Book and WD respectively. I hit Troubleshoot last night to diagnose it and two errors came up, one for the USB and the other for the PCB. So i hope you’re right that it’s a power issue.
If I were a scientist, I’d say it was because I was transferring data from my XP machine yesterday to my Windows 7 that I normally run on.
I think I may go out and purchase an enclosure. In doing so, is it safe to use the enclosure permanently?
So I discovered how the warranty works for Western Digital. First of all, I’m not pleased with customer support, they have ready to read answers and they don’t care about helping you, just directing you to their website or one of their partners.
Sure, you can send back the defective hard drive untouched and receive a replacement but then of course you lose all your data. When I brought this up to customer support/tech support, they told me that I can use one of their partners for data recovery, found here:
They told me to call Vogon International at the bottom. I did and they directed me to Ontrack and they said “No problem! We’ll be happy to fix your drive. The minimum fee is $695 and it can go up to 16…” I stopped listening after that point.
$695 !!! Wow !!! How would anyone place value in a warranty that doesn’t cover data recovery is beyond me. Sorry Western Digital, you’re losing a customer over here.
Good luck in finding another supplier. Seagate’s warranties certainly exclude data recovery costs. I don’t know of any media manufacturer that will cover data loss/recovery in their consumer warranty. It’s been industry standard with all media for at least 50 years, and it’s not looking like it’s going to change any time soon.
