My wd hd can not be detected!
hello everyone !!
I am writing this in order to get help on my data to be recovered on my wd hard disk - passport essential.
I hope I can get some help.
I have shown my hard disk to various people for recovery but I have not been able to receive much help.
These are some of the problems that I have found out with my HD.
  1. The PC board card is damaged.
  2. I have been told that there are a couple of scratches which is visible on the media.
  3. The head assembly is broken as it has been told to me.
The data is very important to me. I have been told that i will have to get the same hd with the same model number and firmware in order to get a recovery done. but its very hard to find the same firmware. can anyone please help me out on a solution ??
Could you please help me if my data could be recovered or not.
Also could you help me with the procedure ??
Your prompt reply will be highly appreciated.
Hi, I think this is a little bit beyond a fix it yourself problem. You might want to contact a professional data recovery company.
http://support.wdc.com/recovery/index.asp?wdc_lang=en
