Can anyone give me any suggestions or is this just a defective drive? About a year old and i have checked out cables, ports etc and all work fine as does an identical SSD purchsed at the same time. Quite new Lenove laptop, running Win 11.
Hi @afinch7
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
I have checked and worked on the drive. The issue was the USB ESD partition which I was able to remove and I think my problem is solved. Thank you for your response and help.
A Finch
@afinch7 ,
If your WD Elements 2TB SSD is only accepting 31GB of data while its identical twin functions perfectly, it may be due to partitioning issues, improper formatting, or a firmware glitch. This guide will help you resolve the problem.
Start by checking the formatting of the SSD. An incorrectly formatted drive may limit its capacity. Connect the SSD to your computer, navigate to “Disk Management” (Windows) or “Disk Utility” (Mac), and verify the file system. For optimal performance, use NTFS for Windows or exFAT for cross-platform compatibility. If formatting is the issue, back up the data and reformat the drive.
Inspect the partitions as well. On Windows, open “Disk Management” and check if the drive is partitioned correctly. Delete and recreate partitions to utilize the full 2TB capacity. For Mac users, use “Disk Utility” to adjust the partition size.
Additionally, visit the Western Digital Support Page to check for firmware updates for your SSD. Updated firmware can often resolve storage or performance issues.
If these steps fail, try connecting the SSD to another computer to rule out system-specific problems. For further diagnostics, download and run WD Drive Utilities software.
If the problem persists, the drive may require replacement. Contact WD support for assistance or warranty claims through their official website.
Was your issue resolved now or not?
Resolved, thank you
I know it’s late, and you probably got your answer, but it’s odd—same SSD, same setup, yet one acts up? Almost like it’s fine but… not? Maybe firmware, maybe just fate messing with you.
Good read. The USB ESD partition (typically displayed as “ESD-USB”) refers to a special system boot partition that is automatically created on a USB drive when using Microsoft’s official Media Creation Tool to create a system installation drive.
Regardless of whether your USB drive has a capacity of 64GB, 128GB, 500GB, 1TB, 2TB, or even larger, the creation tool will force the partition to be formatted as FAT32. However, the maximum partition size that can be created using the FAT32 file system in Windows is 32GB. If your USB drive exceeds 32GB in capacity, the remaining storage space will become “Unallocated space”; this space will not be visible under “This PC,” making the USB drive appear as though its total capacity has “shrunk.”
Once you have finished installing the operating system and no longer require the installation drive, you can restore the USB drive to its original state this way:
1.Right-click the Windows Start button and select “Disk Management.”
2. Locate your USB drive in the list displayed at the bottom of the window. 3.Right-click the 32GB “ESD-USB” partition and select “Delete Volume” (Note: This action will erase all data). After deleting the partition, the entire USB drive will appear as a single block of black-colored “Unallocated space.”
4. Right-click this unallocated space, select “New Simple Volume,” click “Next” through the subsequent prompts, and choose either the NTFS or exFAT format.
A related blog: How Initialize & Format External Hard Drive on Windows PC?
