galhl
1
Hi All,
I am having an issue with my cruzer blade.
My computer recognizes the drive but it won’t show up on my pc.
I though I should assign a different letter to it or format it but on disk management it appears like this:
Altough the driver seems to be installed (also tried re-installing, didn’t work :/) :
I have also tried on different USB ports and on a different computer.
Any advise on what to do?
Is it fixable?
Thanks in advance, Gal.
I am having a similar problem, I was able to format on a different computer but still now luck
I cannot believe 2 other users have experienced the exact same issue as myself at around the same time.
SanDisk I have multiple USB drives and SD Cards from your company and have been a loyal customer.
This problem is unacceptable with recovery software not being able to view any of the files that existed.
The 4GB Cruzer shows up in computer management but has 0% utilisation and says it needs to be formatted.
Supplementary to this I have a 32GB SD Card which shows files within a phone but overheats and shuts down on any PC.
The exact same problem occurs with a card reader which is a major problem not experienced until recently.
