how can i fix it?
Hello there and welcome to the WD community.
What operating system are you using? Try to use the drive on a different computer and check if you get the same error.
Hope his helps you out.
i dont have with me another computer.
what else can i do?
What OS are you using and how is the drive formatted?
Joe
