3 days ago my passport 500gb is not recognized by my computer. but it is recognized by Smartware but it shows “No writable WD Smartware partition found” Device manager recognized it and it shows “This device is working properly.”
Tried using USB device viewer and it shows
—===>Device Information<===—English product name: “My Passport 0730”
ConnectionStatus: Current Config Value: 0x01 → Device Bus Speed: HighDevice Address: 0x03Open Pipes: 2
===>Endpoint Descriptor<===bLength: 0x07bDescriptorType: 0x05bEndpointAddress: 0x84 → Direction: IN - EndpointID: 4bmAttributes: 0x02 → Bulk Transfer TypewMaxPacketSize: 0x0200 = 0x200 max bytesbInterval: 0x00
===>Endpoint Descriptor<===bLength: 0x07bDescriptorType: 0x05bEndpointAddress: 0x03 → Direction: OUT - EndpointID: 3bmAttributes: 0x02 → Bulk Transfer TypewMaxPacketSize: 0x0200 = 0x200 max bytesbInterval: 0x00
===>Device Descriptor<===bLength: 0x12bDescriptorType: 0x01bcdUSB: 0x0210bDeviceClass: 0x00 → This is an Interface Class Defined DevicebDeviceSubClass: 0x00bDeviceProtocol: 0x00bMaxPacketSize0: 0x40 = (64) BytesidVendor: 0x1058 = Western Digital Technologies, Inc.idProduct: 0x0730bcdDevice: 0x1012iManufacturer: 0x01 English (United States) "Western Digital"iProduct: 0x02 English (United States) "My Passport 0730"iSerialNumber: 0x03 English (United States) "575839314142304539313538"bNumConfigurations: 0x01
===>Configuration Descriptor<===bLength: 0x09bDescriptorType: 0x02wTotalLength: 0x0020 → ValidatedbNumInterfaces: 0x01bConfigurationValue: 0x01iConfiguration: 0x00bmAttributes: 0x80 → Bus PoweredMaxPower: 0xFA = 500 mA
===>Interface Descriptor<===bLength: 0x09bDescriptorType: 0x04bInterfaceNumber: 0x00bAlternateSetting: 0x00bNumEndpoints: 0x02bInterfaceClass: 0x08 → This is a Mass Storage USB Device Interface ClassbInterfaceSubClass: 0x06bInterfaceProtocol: 0x50iInterface: 0x00
The thing is, My computer does not recognize it… I need my files… my thesis and feasibility studies is inside my passport…
Firmware + Software is up to date. Was installed correctly.
Drive shows up in “Device Manager”
Drive shows up in WDSmartWare, however it’s permanently - Drive discovering.
Inside the WDSmartWare, “No Writable WD SmartWare Partition Found”
It’s being detected by the green plug of windows showing you have something plugged into the USB-hubs.
I’ve ran scans to see if the drive is broken, corrupted or any problems. There are none, perfectly intact with the original cable which is not damaged either.
Made sure it’s a Windows My Passport and has worked before and it stopped once I updated the firmware and software.
Does not show up in My Computer yet it’s clearly that it’s detected but just won’t register.
It does show up in “My Computer”, “Manage” and under the “Disk Management”, it’s online but not accessible.
Dear community, help us since that’s what a community is for.
Sorry, I wasn’t sure what you meant by “scan”. If you were able to perform a surface scan via a software application, then obviously the drive isn’t password protected. However, if you used Data LifeGuard to perform an internal self test, then AFAICS this test would proceed whether or not the drive were password protected.
At this point I would use a disc editor to examine sectors 0 (MBR) and 63 (boot sector). If you can see these, then this would suggest that your drive may have a logical problem. Otherwise, if you can’t access these sectors, then I’d suspect a hardware fault.
I’ve plugged the Drive into friends computers, both PC and Apple and find the same thing. (The apple however shows a bit more info on the contents of the drive than the PC) However in both cases the drive does not show up in the My Computer menu.
Unfortunately I need the data. So that solution is not an option for me. Thank you anyway. Anybody else out there have a solution that doesn’t erase my data?
I have the same problem. I have a 500gb My Passport (supportinh both USB2 and 3). The disk worls properly, keeping showing data stored on several PCs who runs Windows XP and one who runs W7, but in both my PC (W7 32bit) and laptop (Dell N4030 with W7 64bit) appears briefly on Computer Management -Storage- Disk Management , allegedly unformatted, and every minute a “You need to format the disk” appears, but, even when I go to disk option, the system is unable to format the disk.
The unique path I didn’t try is to reformat any of my computers.
Still not having any luck. I have tried on another computer, and I have tried with a different cable. I don’t want to reformat, becaue I have a lot of information on the HD still. Any new ideas?
I just signed up today for this forum for the same reason, its sad that WD reps aren’t on here to lend support. I replied on another thread about this problem, but here is a possible fix for some. When I plug my passport in to my PS3, it is still recognized and accessible. You can access you files from there and move them to another storage device and then re-format the passport.
This didn’t work for me because I didn’t have another storage device large enough to store 400 gigs of info. I’m pretty pisssed considering I didn’t drop my drive. My problems started after I downloaded a movie to my HD.
