My Passport Ultra - Admin rights required to copy to new laptop?
I backed up all my files from Win7pro 64 bit o the Passport Ultra and just got a new computer win10pro 64 bit.
I can open the files, copy to and from win7 (the orig laptop) just fine…
When I try to copy, move or open any files/folders/zips form My Passport Ultra, some of them copy over just fine…and some of them ask for administrative rights and I have no choice but to cancel the copy to the new laptop.
I have tried to change “permissions” on it…and it helps for some of them but still some of them still want admin privilege approval.
How do I remove that so i can copy my files/folders ?
I would do a laptop link from one laptop to the other but he prob is, once I saved some of the filed/folders to the Passport, I deleted them off the old laptop…So I NEED to get to those folders.
Why are there admin permissions required? I never put any security on the thing in the first place.
Please help!!!
Thank you!!!
Hi ITS,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support if you are having trouble with the form.
