My passport SE worked fine on Windows and Leopard, could use on work pc (Windows) and my home Macbook Pro without any issue. I then “upgraded” the Macbook to Lion and can no longer access the passport SE portable drive. Is there a “work around” so I can still use the same portable drive on both systems? Geoff
Geoff47:
You can update the firmware of your product clicking on the link that i posted right below. Please before you update the firmware of your product I strongly suggest to do a backup of the information that you have saved on the external drive…
WD UNIVERSAL FIRMWARE UPDATER FOR MAC AND WINDOWS
Note: Click the Kudos star to say thank you for helpful posts. And click the ‘Accept as Solution’ button for the post that solved your issue.
Well that did not work. I had previously tried these downloads but did it again and the drive structure is still not seen. I can unlock the drive but finder does noy see the folders. Any other ideas?
