I would like to be able to format the drive so it could work on PC or Mac. How can I do this?
I read the manual but it didn’t really help me.
Thanks
Thanks
Well there some different things to try. One is format the drive FAT32 and both will be able to use it. The down side is the largest file you can have is 4 gig. This should help http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3865
The other thing is format the drive NTFS for Windows and download and install this http://mac-free.com/download/NTFS-3G.html on the Mac then both drives should be able to use the drive. Just test it out with some small files before you fill the drive.
Joe
