My Passport 320 GB Suddently not Recognized any longer
Hi
Yesterday my pc suddently wouldn’t recognize my external WD my passport. However if I leave in and restart the pc it appears in “my computer/harddrives”.
I’ve tried changing the usb cable without succes.
The Passport drive appears in the disc management with an assigned drive letter.
hope anyone can help my out on this one.
In advance thanks
Erik
What model passport?  What OS?  Are you using a cable 18 inches or less?
Hi
It’s a passport Essential, I’m running Vista 32bit and the cable is a 18" one.
\Erik
Does the computer stop recognizing the drive after it comes out of sleep/hibernation?  If so, you may need to look into Vista’s patches for the USB ports.  That was happening a lot when Vista first came out.  I’d also make sure that you have all your Vista updates.
Hi
Now it does recognize the drive again, without me even trying to solve it. So I’m not sure what actually happened.
\Erik
That’s good.  I’d still make sure that I had the latest service pack (if Vista has one), and all your updates.
