i had connected my passport 4 tb to a smart TV using USB connection!
after that when i connect it to my PC it gives me a message “isn’t accessible” - “access denied” what can i do with this problem ?? i am in deed need for the files in fastest time !!
using Windows ?
run chkdsk
yes
Press Win + R on your keyboard and type CMD and then enter. Run CHKDSK /F D:
Replace D with the letter for your drive. Hope this works!
There could be various reasons for an external hard drive to become unresponsive or undetected. It can be a hardware issue or some technical issue in the software.
You can try the below options to resolve the issue:
- Run CHKDSK
- Use an Antivirus & Anti-Malware tool
- Re-install the drivers
You can also check out the below link to know the solution for an issue: https://www.stellarinfo.com/blog/how-to-fix-not-responding-hard-drive/
Hope this will help.
