Hi, I have a 1TB My Book Mirror and I want to replace the hard drives. Inside it says to replace with any “Green” drive. What is the maximum size I can put in here? I am running win7 64. Can I put in 2 x 3TB ?
Thanks
Thanks
Not sure if you will be able to use bigger drives than the one that came with the unit due to the time that your unit was manufacturer. However, they are other users that reported that they were able to do so.
Check the link below
http://community.wd.com/t5/Other-Network-Drives/MBWE-ii-increase-capacity-to-2x-2TB/m-p/426060#M8377
