Its the second My Book Essential that is no longer recognized… I have a MAC and I am completely lost…
I don’t know what to do.
Please help me…
Please help me…
Welcome to the Community.
What have you tried so far? Did you check your Mac’s Disk Utility? Did you change the USB cable? Did you try other computers?
For instructions in order to access Disk Utility and diagnose your hard drive, please visit the following link:
Hello I have already tried disk utilities and I am afraid the particioned disappeared… it is the second WD my book essentials to do the same thing…
What next?
I want to jump off hte window…
I use a Mac, and I use the drive properly and a normal ammount of use it had less than 1.5 TB used out of the 3
Im so bummed
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
Support by Country
http://support.wdc.com/country/index.asp
