I have a MY BOOK ELITE 1TB - PAN-AM that I bought from Costco, well, I’m not sure when, but the warranty expired 11-Dec-2013, so it’s at least 7 years old…probably closer to 8.
I don’t remember the last time that I used the drive, so I’m not sure when the problem started. The basic issue is that when the unit is plugged into power and connected to my computer via the usb cable the computer doesn’t seem to recognize it - nothing shows up in windows explorer, etc.
The power light in front is on. My initials show in the led screen (that must be what I named the drive). I recall there used to be an indicator of how full the drive was on that led screen. If so, that’s blank.
What sort of troubleshooting is there to do? What are my options? Do you suppose the usb cable is bad? Do I have a very expensive brick with a lot of data in it?
Thanks, in advance, for your assistance,
wollernwd
